OF1400 Router Base DWG or DXF
capww8
Anyone have a CAD block showing the screw positions and shape of an OF1400 router base?
Resurrecting this old thread as I've just created a PDF showing the router base viewed from below. Unfortunately I can't add a DWG or DXF as the file type is not allowed.
The small circle in the middle is obviously not part of the base - I used this for drilling holes in a circle template and the small circle is for centering purposes.
How did you take the measurements? And probably should have included the outer measurements too, just for completeness :)
Digital calipers, Ben. If you print the PDF at 1:1 or full size you can use the print as a template (print on paper, card or film and then use tape to fix it to whatever you are machining)
