Michael Kellough
Certainly you can use the regular dust deputy. I have a set strapped to the top of a CT Mini so it has a small footprint and is plenty mobile. Heavy duty bungee cord has worked well enough even moving up and down stairs. Tucked a short cord power strip under a bungee that crosses the top of the bucket so the plug it cord can connect closer to the vac hose.
As Gregor said much earlier with drywall dust the surface of the bag will get clogged even though it seems empty. Of course it will last much longer downstream from the dd. You can get some more use from the bag by simply thumping the surface all around.
