Outdoor Mahogany Table
eddomak
OK, I might as well post my other project that was the start of the recent trend of building things...
Last November (2013) I decided to build my own outdoor table rather than buy one, and it's been over 20 years since high school woodworking, but I am generally OK with tools, and remembered some of the techniques.
I decided to build it from mahogany, as it would be nicer than Merbau (which tends to bleed tannins), and far less expensive than Teak (especially if I made a mistake). Also even though the lifespan is less than teak, since the joinery would be purely Kreg pocket hole joints, then I didn't want the wood to outlast the screws. Also it would give me an excuse to build a replacement.
I wanted to spend more time on a nice design, rather than too much time in crazy joinery that was beyond my ability. The cocentric mitres had a lot of interesting things to solve - how to get the right lengths, how to get those visible lines aligned, how to provide support from below, etc.
First session was not so good. Despite planning everything on Sketchup, I found out that in the real world wood isn't that precise
Sketchup model:
[attachimg=#8]
- so I ended boxing myself in without enough gaps. (Lesson learnt and applied on the 2nd session - work outwards)
[attachimg=#1]
Also I had no experience with how exact mitres needed to be over 1800mm, so had some problems with open mitres on the outer frame (cue lots of searching for solutions on YouTube). Note that mitres on the internal layers have an intentional gap for drainage and to emphasise the design - these gaps worked in my favour because it could be less precise.  [wink]
[attachimg=#2]
Built the legs and frame in 20 minutes with pocket screws...
[attachimg=#3]
Close up of the pocket screws...
[attachimg=#4]
2nd session got it all done, and this is before finishing...
[attachimg=#5]
Another angle...
[attachimg=#6]
"Finished" with a lot of outdoor furniture oil (I didn't build the chairs)...
[attachimg=#7]
I had no idea or experiences with finishes, so have been quite happy with how it has turned out. A couple of months of use and I decided to do a 6mm roundover as we kept getting marks on our forearms.
If only...
- I had a Kapex at the time (the dust and subsequent cleanup was terrible)
- I had a TS55 and MFT at the time (I could have put all the boards together then cut the mitres in one go)
- I had a Domino - it would have made the joins so much stronger and easier to align
But I loved the project, loved the outcome, and learnt a lot. Also it has got me building a lot more since then.  ;D I have also discovered Festool - woohoo!
Neat looking table and a great excu....learning experience to get the fine Festoys you mentioned above [big grin]
MarinerMonty said:
Great looking table! Did you use 4x4 mahogany for the legs ?
Thanks! They are 2 laminated 45mm x 90mm posts to form a 90mm x 90mm post.
Update: It's been almost a year outdoors now, and just past autumn and most of winter, and I still enjoy the table. It looks like time to give it another coat of oil as some patches are uneven in colour..
Very nice!!!  Really love the color once oiled!!!
I like the design.  I'm guessing you pocket holed the boards connecting at the middle.  How did you connect/join the outer boards (i.e. What keeps the boards in place and level between the boards as you do have a gap between each)?
Yes, the boards are pocket holed to the middle. (Note: always drill the more expensive piece of wood in case the receiving end splits  [scared]).
There are actually a couple of cross-braces in the frame, set perpendicular to the top pieces. At first I tried not having any perpendicular to the end pieces and just set those short top pieces on them them lengthwise, but they rocked, so I inserted a couple more to prevent rocking. I could tell that one day someone (me or the kids) would stand on the table in exactly the wrong spot and potentially put a foot through... Pocket screws were ideal for installing those additional short braces in-situ.
