I'm one of the latest folks to pick up the lovely Parf Guide system Mk II. I'd been checking the website pretty regularly, and when I saw 3/19 they showed in-stock, quickly put my order in, at 10:40am CDT. I figured since it was nearly 4pm UK time, particularly considering the statement on the website, it'd get shipped out Wednesday, maybe Thursday, arriving today, or maybe Monday the 25th.
There was some hiccup, my order never showed past Processing stage, and so I called Thursday to check-in. They quickly looked into it, emailed me the tracking info, and I soon learned it was due for delivery Friday...only 3 days after ordering!
I'd also bought a few of the 1M, parallel jaw Trade Clamps, plus 2 extra Parf rulers. Everything was well packed, the box had a slight kink in the middle, but that's because the clamps are thicker at the heads, so the middle was unsupported there. No impact to anything inside that I could see. About $30 to have a 1M long, 23Kg parcel delivered internationally in 3 days was quite reasonable.
I was able to use the set to drill up a nice grid of holes in a board this weekend, and it worked a treat. The only quibble I had was the aluminum clamping collar wore through it's anodizing on the outside edge, where it rubbed against the drilling guide. Still perfectly functional, just a little uglier. I'll mention that to Axminster directly as well, in case they're not aware.
I don't know if the kit has changed slightly since the Mark II was introduced. [member=59331]TSO Products[/member] has said they include a stainless steel clamping collar instead of (in addition to?) the set screw collar. At this time, the provided collar is an aluminum clamping collar.
Also, the Mark I rulers available separately, seem to be Mark II rulers, with the 11 3mm holes drilled. Peter mentioned they were going to be using the Mark II stock for these, but it seems they're using completed Mark II rulers! [blink] No complaints here. [big grin] Having the full Mark II hole pattern is a nice bonus I wasn't counting on. I'd planned to do some experiments, to see if 2 "Mark I" rulers can be used, and still get precision intermediate holes (32 and 48mm spacing), using Pythagorean theorem. I did some layouts in software (seen below), but haven't seen how practical they are to achieve in practice, and the minimum board size needed to allow for this. [member=11196]Peter Parfitt[/member], I'll be sure to pass along what I find if you want to share with your viewers, or you're certainly welcome to run with the idea yourself.
