tjbnwi
- May 12, 2008
Haven’t forgotten about this. I have a surgery coming up (nothing major), I’ll do this during my down time.Thanks!
Yes, jambs sides are represented by the lines, the MDF piece represents the case. They run close but do clear.Thanks ever so much for taking the time!
Just to make sure I understand correctly:
The (in the photo) vertical lines on the worktop represent the jambs and the pieces of MDF the pivoting bookcase? If so, then that is indeed "close". Very nice though. I gather this way you won't need angled pieces to make the turn?
What is a "courtesy cut"?
With preventing "ghosting" do you mean preventing scratching of the floor, which would be a giveaway there's a hidden door?
I was so focused on the sides of the case, that I had underestimated the importance of the base and I certainly would not have thought to make sure there would be enough space on the top side. It would be just like me to forget about that and only realise when it would be too late.
I think I can have a local metalworker make the hinge parts for me, so don't expect there will be no problem on that part.
Seeing this, I suspect it might be a good idea to first design the whole thing in BricsCAD to make sure everything will actually move and fit as intended.
Thanks again!
Thank you. The surgery went well, the recovery will suck, I have no clue how to handle two weeks of no work then two weeks of light duty.Good luck Tom, hoping you have a great recovery
I quoted you again because I thought of other things that may help.Thanks ever so much for taking the time!
Thanks again!
