nickao
- Feb 24, 2008
The CT is not handling either one of those planers more than a few minutes. Bench top or not I got horrible results using anything but at least a 1-1.5HP induction motor dust collector with a planer, min.
If you are buying a planer that is not a bench top(ie a 3hp 220 V 400lb machine) you have no business unless you have a real dust collector anyway. I would not base what planer I got on the vac, but the dust collector on the planer. If you get that Grizzly Planer you should purchase a little 1HP 4" dust collector dedicated to it at the very least.
So yeah, stay with a bench top planer if that is your mindset.
Once you get the knack for your machine changing the blades is not an issue. I change blades on a machine some people say is horrible(for blade changes anyway), I never noticed, you just get used to your machine.
