Porter Cable PC 42700 Router Edge Guide
Status
Not open for further replies.
nickao
I said ONE OF THE LAST ITEMS. I keep finding stuff as I clean my shop!
Never used in the original packaging and unopened!  Sells for 67.00 at many online stores! This is for the bigger porter cables not the 690's or 890's.
I am asking 42.99 and FREE shipping!
Porter Cable PC 42700 Router Edge Guide Jig Bit - Top of the line
Sells for 67.00!
Technical Details
    * Durable aluminum construction
    * Dual sliding, lockable mounts
    * Precision fine-adjust knob
    * Fractional and metric Scale
    * Quick and accurate operation
Product Description
The Porter-Cable 42700 Precision Router Edge Guide has a large fence for smooth handling while routing. This edge guide features solid construction with an anodized, extruded aluminum body for strength and durability. The dual sliding and lockable adjustment mounts let you quickly slide the edge guide to the general area needed. Once you lock down the first slide and rotate the precision fine-adjust knob, the edge is exactly where you need it. The adjustment scale is in both fractional and metric increments. It will fit Porter-Cable routers models 7518, 7519, 7529, 7536, 7537, 7538 and 7539. The edge guide and mounting hardware are included. It comes with Porter-Cable's 1-year limited warranty.
Product Description
Porter Cable 42700 This edge guide features solid construction, with an anodized, extruded aluminum body for strength and durability. The dual sliding and lockable adjustment mounts, let you quickly slide the edge guide to the general area needed. It feat
See all Product Description
Product Details
    * Product Dimensions: 17 x 9.8 x 3.2 inches ; 3 pounds
Status
