windmill man
- Aug 26, 2007
Think you could get it to work but wont be the most robust piece of furniture. Can see the advantages of steel here.
Guy Ashley said:Graham
Just a thought, it may be possible if you could bore out a 12mm hole and insert a length of stainless steel rod which could somehow be mounted to a bracket on the base of the table and could be hidden by the top of the legs.
If I had skills with Sketchup I would draw something.
The load bearing would be taken by the rod then.
windmill man said:Think the top is frosted glass.
jmbfestool said:I forget about jigs lol cus they take time and don't always have the time to make jigs so always think alternative options ie a tool which can do it with no jig.
Jmb
Archemedia said:I think this is a great idea! But... suppose this thread is a huge success and hundreds of plans are posted... how you'll find the one you like? Shouldn't it be better to have a seperate forum in here where every thread is a project plan? Maybe the moderator could comment on this?
Dany
Guy Ashley said:Just a thought, it may be possible if you could bore out a 12mm hole and insert a length of stainless steel rod which could somehow be mounted to a bracket on the base of the table and could be hidden by the top of the legs.
Dany
