Dave Ronyak
- Jan 23, 2007
Another way to look at this issue is to ask why those craftsmen who made real M&T joints also added corner blocks. Corner blocks also provide a structural backup in case the primary [M&T] joint happens to work loose, e.g. glue failure. If you want to go "all the way" use dovetailed corner blocks. I typically route [dado] a 1/4" groove on the inside of the aprons and corner blocks of table that I make and use these grooves with shop-made L-shaped blocks of hardwood scraps to fasten the table tops to the aprons and the corner blocks with screws. That allows the top to float relative to the legs and aprons yet also serves to further distribute any loading. Part of any twisting load on any leg, e.g. when someone pushes a table to move it, is transferred through the corner blocks to the top and to the apron railings joined to any leg rather than having to be carried entirely by the M&T joints and the fastners holding the aprons to the top.
Dave R.
Dave R.
