Forrest Anderson
- Jan 23, 2007
It is interesting to note that Festool sells wire brushes for the RAS115, advertising them "for the removal of rust and slag" - but they are NAINA (not available in North America).
For those who are new here, I have taken the liberty of reproducing a post I made in July 2007 about the RAS:
Good question! The entry in the US catalogue for RAS115 accessories looks like this:
Note how there are hard and soft StickFix hook and loop pads (484172 and 484173) and a FibreFix pad "with arbor for grinding discs" (485298).
Festool have tried to explain the difference in their FAQ database:
Question :
What is the difference between the FiberFix and the StickFix sanding pad for the RAS 115?
Answer :
The StickFix pad accepts hook and loop sanding discs. The FiberFix pad has an arbor to attach grinding discs.
At first sight it appears that we can attach grinding disks to the RAS115, but there's a catch! If we look at the US version of the RAS 115 official manual, we get this list of list of speeds for different materials and a warning:
This warning, in no uncertain terms, rules out the attachment of metal grinding disks, and the speed chart makes no mention of using the sander on metal. It therefore appears that the US catalogue supplies a grinding attachment, but the US manual prohibits its use on metal.
Exploring a bit further, the UK catalogue has lots more accessories for the RAS115, and UK customers can also get the RAS180, which is larger:
And look - two types of cup brushes and a circular brush - "for removal of rust and slag" and "for paint and rust removal".
There are also two more items of interest:
So there are quite a few metal grinding accessories available for customers in the UK! Let's see what the UK manual says:
Notice how it says "Designed for sanding wood, plastics, metal..." and how the speed chart includes "sanding painted metal to remove rust".
In summary, it seems that UK customers are allowed to sand/grind metal, whilst US customers are not. Presumably this was one of the conditions for UL approval for introducing the machine to the US market. I therefore suspect that the inclusion of the "FiberFix sanding pad with arbor for grinding disks" in the US catalogue is only there for users who want to use disks designed for grinding stone and concrete, which is allowed.
Forrest
Note that the references to catalogues and manuals were for the versions available in 2007, and changes may have been made since then.
You'll see from the above that Festool also sells the RAS180, which is the RAS115's bigger brother. However this is also a NAINA item. Here is a comparison between the two siblings - note the difference in weight and power, and also that they are 1/3 to 1/2 slower than typical angle grinders :
Forrest
minimal said:The RAS 115 looks an awful lot like an angle grinder; I also see in the current catalog that there is a "FiberFix sanding pad with arbor for grinding disks" listed in the catalog.
But I see no grinding disks themselves.
Does anyone know what grinding disks it accepts, and has anyone used this for metalwork? I need something that will clean up steel after being cut/worked with a torch...
Question :
Answer :
- Clamping nut SM-M14/D115, For RAS 115, for securing Fiberfix sanding discs, 439581
- Spark trap for dust extractor D 50 FL, For use when sanding materials that generate sparks, 484733
Forrest
	Forrest
