Kodi Crescent
- Aug 6, 2010
I have a built in cabinet that I built for a finished attic. The overall width of the cabinet is about 9', and its built from 4 boxes tucked into the attic knee wall. A 5'x9' Poplar face frame ties all the boxes together. This was my first time building something like this, and when I installed it, I didn't factor in that I'd have to seal the finished attic space from the unfinished attic space. It's a tight fit, and its a bit crooked. There are gaps between the face frame and the drywall. Gaps large enough that backhand trim really can't cover. (I guess it could, but the scribe would look terrible).
The cabinet is built relatively tight to the height of the wall and the sloping ceiling. There's about 1.5" or less of drywall at the margins of the face frame. VERY difficult to float.
So as I'm trying to get this tighter so that I can seal the space, I have a couple of options.
1. Smack the face frame with a sledge and hope to "convince" the boxes to go in further. (It was a tight fit!).
2. Remove the face frame so that I can add a sheet of drywall behind to shim it out farther from the wall. The problem is, I don't remember how I installed the face frame. I at least nailed it. But I probably glued it, too.
I want to avoid taking the Multimaster to the frame. A frame that large was a real pain to create. Jack mitered joints and all. Are there any other non-destructive options to try to separate the box from the face frame? Add tall back band instead of drywall? (It may be 1.5" tall ) that I can caulk to seal? Any advice is appreciated. Thanks!
