Renofix grinding epoxy on garage floor which disc?
BJM9818
Have a single car garage to remove a failed one layer epoxy coating.  Which disc would be best to use ?  Thanks!
I would attempt the gold colored diamond paint removal disk. But if it is failed in that it never fully hardened, the blue wheel for thermoplastic materials may work better.
I would peel or scrape off as much as possible first. Maybe get some water underneath it to get it to detach. Sand off whatever is left.
Not a fan of sanding that epoxy crap. Watch your sander speed. That stuff tends to get gummy if speed is too high and it gets hot.
