Replacement pad for Festool RO 150 E ( 489873)
Jack01
I have old Festool RO 150 E , till this day it is working well.
I need to replace the pad for this sander,
I did some search and looks like  pads 202458 (soft) or 202460 (hard)  will fit this sander
Before I place an order want to make sure that these are correct parts.
Any help will be appreciated.
Hi Jack, (never say that on a domestic flight)
    The RO150 has three replacement pads.
[list type=decimal]
[*]Sander Backing Pad ST-STF D150/MJ2-FX-SW Item number 202462 Super Soft for slight curves and arcs...
[*]Sander Backing Pad ST-STF D150/MJ2-FX-W-HT Item number 202461 Soft general purpose pad....what comes with the sander.
[*]Sander Backing Pad ST-STF D150/MJ2-FX-H-HT Item number 202463 Hard pad for flat surfaces...this is what I use the most.
[/list]
  Hope this helps...
I have the same question and I want to be sure it's answered before I purchase the pads listed above.  Will these pads fit the original Rotex 150?  Mine is the first Festool I purchased and it's been a workhorse but the pad finally fell apart.  I know the pads listed will fit the current production Rotex 150 but will they also fit the original model?  Is the pad attachment system the same for both models of the sander?  Thanks in advance for your help with my question and sander.
