fuzzy logic said:I'm not Darita - but thanks for the link Garry - interesting read.
Subsequently googled "different grit standards' - which (of course) brings up zillions of hits.
One quickly looked at might also be helpful, because of way info' presented:
http://www.mibnet.se/home-improvement/sandpaper-grit-size-comparison-between-european-and-us-standards.html
But…just curious Darita, as to what (so it seems to me) is behind your confusion.
Are you going to use Festool abrasives, or, looking to use ‘equivalents’ from another supplier?
Richard.
Richard,
I'm going to be using Festool abrasives, at least for now. Are there equivalent abrasives?
darita said:I see that most of the grits I'll be using are pretty equal to what we use, only with a P in front of it. I guess my confusion is with the Titan, Saphir, etc. What are those?
Brice, sorry for asking so many questions. What can I say...guilty as charged.Brice Burrell said:You should try searching the forum before starting so many threads. All the answers to your questions are readily available here. Here's an example, the Festool abrasive details thread, is sticky at the top of this section of the forum (and currently at the very top).
TurnagainD said:I'm with Scott, we just use Granat. It works just fine on bare wood and I don't stock multiple papers. We use 40 and 60 quite a bit. The best part off the rotex is how fast it removes rough stock. Definitely a learning curve though.
darita said:Bob, thanks for the help. You'd know, as a seller of all this stuff. Seems like you can't go wrong with Rubin2 or Granat. I don't have my RO150 FEQ yet, but when I do, you'll be hearing from me again.
darita said:TurnagainD said:I'm with Scott, we just use Granat. It works just fine on bare wood and I don't stock multiple papers. We use 40 and 60 quite a bit. The best part off the rotex is how fast it removes rough stock. Definitely a learning curve though.
Please, tell me more about the learning curve. I thought a sander would be a sander. How does it act differently and what do I have to learn? All good info!
