I regularly make frame and panel cabinet doors in a simple style - glued in flat panel with no bead - sometimes casually thought of as "contemporary" or "shaker". I need to do these faster. I've been using my Sawstop (love it!) to get a centered 1/4" dado down the middle but that leaves the question of what to do with the gap this leaves at the top and bottom of the assembled door. Making the cross member have a tenon is one approach but I'd like to do this faster than that. I could cut the frames on diagonal and hide the cut - don't like that look. So what about using the 1400 with the routing aid to do this? I could stop the cut from each end that way. I will be getting a 1400 and KR32 kit anyway to speed up and improve the look of my cabinet holes, so the expense isn't really the issue (although $251 for plexiglass is buckets of bucks). Then I'd put dominoes (which I already own and use when doing cope and stick for more strength) in each of the 4 corners. That would give me the look I want and the domino has to be faster and more accurate than making a tenon.
I'd be open to other approaches including being told "make the tenon". But I make alot of these and want to be more production oriented.
Secondly, having read other 1400-related threads here, what optional accessories are most recommended? The hard fiber base runner and guide stop appear no-brainers. And can the 42" hole rail be used and then moved up for longer lengths of needed holes or is the 95" the only practical way to do that.
TX in advance cause I know I'm asking alot of question but I'm finding Festool is starting to make me good $ so I want to pursue it hard.
