GPowers
- Mar 1, 2010
The attached picture show the different type of sandpaper and sander pads Festool has. Starting on the top with the original hole configuration, the middle with MULTI-JETSTREAM and the bottom the newest MULTI-JETSTREAM 2 .
Are these paper and pads interchangeable? Examples:
Can MULTI-JETSTREAM 2 paper be used on the original hole pattern?
or
MULTI-JETSTREAM 2 paper on a MULTI-JETSTREAM pad?
Are there combinations that will work and some that will not?
Also the new MULTI-JETSTREAM 2 pad fits on the original ETS 150/3 sander. Will the dust collection work correctly? I assume the collection ducting is done in the pad not the sender. Since that sander just has a fan built into the bottom.
I tried installing the new MULTI-JETSTREAM 2 pad (super soft, Gray) and paper with 800/1000/1200 Granat MULTI-JETSTREAM 2 paper on the original ETS 150/3 and got a lot of dust build up on the paper after two or three passes (left to right) over a 40" inch long table top (with a Poly finish). Thought the new MULTI-JETSTREAM 2 configuration was to prevent this?
or
