Setting My New Shop Up (Formerly Shop Build Progress)
Check our metalbarncentral.com. Looks like they are in the area your going to. I did my 30x40, with pouring the slab for just under 20k, but opposite side of the country. And I had them add some 1/2” insulation board under the metal, definitely seemed to help even before I had the inside finished. Whatever you decide will be well worth the time and effort believe me.
[member=39086]JBag09[/member]
Thanks for the info. I sent them a request for quote and requested the shop be insulated to with stand the Az heat. I went for a 36X36 with a lean to. So lets see what they come up with
@jobsworth , great interested to hear what they come back with. That’s a great size too.
  I studded out the inside of mine and then did r-19 for a total of r-22 with the insulation board and drywall. The ceiling I used a vapor barrier and 1/2” plywood (since I got it for free lol) and then I blew in insulation, ended up around r-60. I did all that myself and I’m sure it saved me ALOT in the end. I think I came in around and 10k, which included all the framing, insulation, electrical, mini splits (my son does this work so he installed them) and a new 5hp dust collector.
It will be interesting to see. I did ask them if they could insulate during installation. Just to see if they could and what the cost would be. My thing is to get the shop built and usable quickly.
There is a lot of building going on residential neighborhoods with a lot of residential housing going up. I mean a lot.
I want to set up and capitalize on that.
Building garage cabinets for the front wall of the garage high enough off the ground where they can park their vehicles comfortably.
Im thinking there will be a need for that and may lead into to other work. Just small jobs what most contractors wont do because its to small of a job. Custom shelves, etc.
Of course Im retired from my career job, but this will keep me busy and I can use the money to help defray the cost of the shed and for some home improvements of my own.
If i get enough people wanting them I can batch them out. Festool is awesome for that sort work.
That opens up an interesting two way street. You want to build a shop and you may need some trades to help you get things done quickly. You can stop by nearby home building sites in varying stages of construction and meet many different trades that might be able to do work on your workshop. In the process you will probably meet some guys that, while they are not general contractors they do consolidate a number of different trades for the builder. Those guys can give you work or even work out barter arrangements to get your shop done quickly in exchange for work they might need. Great idea!
A couple of thoughts.  Regarding insulation.  I think that is key as this better allows an AC unit to keep up with very high heat and saves utility $.  I think reading about R values is a good use of time. If the framing is 2x4s, consider adding some  strips to have a larger cavity between the studs to accommodate more insulation.  That could be R-Max rigid foam (available Home Depot with high R-value per inch) or the other less expensive easier to install options.I think split is better than window which is better than portable.  A central can be use for larger structures where the air handler is suspended and really, there does not have to be much ducting or any ducting.  That would give maximum cooling.  If you like working in the heat, not a problem.  If not, then it will be no fun when the inside temp is 80+ degrees.
Another thought is that if the structure has windows and you can remove a window and build an enclosure for the dust collector outside the opening where the opening allows the duct to exit (and air return), an advantage could be an ability to empty the bin without a dust cloud inside the shop and that space saved inside the shop can be used for other things.
Of course all about priorities and personal preferences.
Good ideas.
On another note, is your name truly “Martin Felder”?
Cheers. Bryan.
I have a ten foot ceiling in my garage and an exterior wall so I had an A/C contractor hang a central A/C (with a small electric heating strip). The evaporator coil and air handler hang from the ceiling in the space just above the garage doors. There is a small plenum with one duct. It works amazingly well and I am in Houston where it is very common to have 5 months of 90 plus degree weather with dozens of those days potentially being 100 degrees plus.
Been a while since I posted a update. Today the county came out surveyed the area where the shop is going to be built took some photos for the permits. So its progressing. I got a feeling that hos will be one of those things that drag and drag and drag but once it starts going bam itsll be done fast. (fingers crossed)
I have about a 30x30 for the main shop then other adjacent space for larger wood and regular tools. I didn’t build myself.
—will there be other uses(vehicles, seasonal storage, etc
—be careful what size O/H door you get as you lose a lot of space/efficiency . Also consider where your service door is in regards to moving things in/out. I would opt for a more rectangular shop as wall space vs center of the room floor space for me would be more valuable. I would also ask myself what are your biggest 3 issues in your current space as well as what you like about your current space
How exciting it must be, congratulations!!!
I have a shop in Queensland Australia. Similar heat to AZ but higher humidity. It is south facing and shaded by a taller structure to the north, and fairly well insulated. It doesn’t have AC and I can comfortably work through 35degree (C) summer with door and window (both south facing) open, I do however have an 84” Big Ass ceiling fan which is fantastic.
Pretty small shop - 18’ by 14’. I’ve got a full sized table saw, jointer, thicknesser, workbench, mitre station, bandsaw, ducted DC, some storage and no room for anything else! Tall ceilings at 12’ which helps. Lots of racks etc to allow storage above machines etc.
[member=72399]CeeJay[/member]
Ceiling fans are on my list to put in. Not sure how many yet. Im guessing maybe 3.
[member=72021]Thompmd[/member]
This is a stand alone shop nothing else going in it. It will have a 8 x 10 storage shed built on to it. I got enough land if I need more storage I can always just build another shed. It would be out of siding and Id build that myself.
Since I have pretty much all festools the only stationary tool is my jet jointer. The rest are festool/bench top tools. I use my CMS GE with my TS 75 for a table saw and my CMS VL for a router table and made modules out of plywood for other bench top tool to mount in them.
Like my Ca shop Ill get some spur shelving to set the modules /bench top tools on. Ill definately be utilising the walls. As far as additional storage lumber etc, Im thinking of building a leanto on one of the exterior walls a place to store my landscaping tools .
Its all in my mind at this time. Wont know until its actually built and Im setting it up and resetting up and and until Im happy with the lay out for work flow.
Im thinking work flow will determine shop lay out. a Guido type  wall along the back should do me about right for sustainers small parts storing finish etc.
Signed the contract today, they should be digging for the slab by the end of the week.
That’s pretty exciting! We did this 4 years ago. Took 12 months from signing contract to moving in. But that was for whole block and house inc workshop.
Im thinking work flow will determine shop lay out. a Guido type  wall along the back should do me about right for Systainers small parts storing finish etc.
You should get a Bigass Fan
Rather than start a new thread, Ill just keep this one going. So today it begins.
they came out and dug the trenches for the footings.
How cool! I look forward to following the build, there can’t be sawdust soon enough and with a good dust extractor there won’t be any lol
