Shop-made custom length Dominos for a job
Crazyraceguy
Festool Moderator
Festool Moderator
I have done quite a few of these types of cubby-hole cabinets over the years.
Making Dominos long enough to go through the shelf portion and extend into each vertical member simplifies this process a lot. 25mm into each and 20mm of shelf, so I made a few sticks of 6mm and rounded the edges. Then I cut them to 65mm. I'm so used to 6 x 40 that they look a little funny
Nice, especially with the small recess for the vertical members.
Just curious:
1) I assume you felt that 8mm dominos were too thick for the wood stock. Strength isn't an issue with this design, tho.
2) I assume that the clamps shown were to clamp the side end pieces on to the already glued center assembly, rather than have long clamps going across the whole width of the piece.
3) What did you do for Wide/Tight on the domino holes? My instinct would be Tight for the front holes only in both horizontal and vertical members, and Wide for everything else.
4) How did you stage the main glue-up? Did you glue a horizontal row at a time and then add as each dried?
5) With the demise of physical mail, cubbies would seem to be relegated to things like shoe racks in the home or display racks in retail. What are these for?
[member=77266]smorgasbord[/member]
1)I generally use the 6mm Dominos in 3/4" material, just out of habit (and supply) I have far more 6mm than any other size. In cases like this, I reference the part and the bottom of the machine against the workbench.
That's why they all have a black marker line on them. That may not show in the pics, but it is there.
2)Yes, the clamps were just temporary. There is enough curve to the entire unit that clamping across would require tapered cauls. Since neither side of this unit will show, when installed, the sides got screwed on.
3) I did tight on the horizontal parts and medium-loose on the verticals. I used standard 40mm on the bottom, inserted them and then set the first row of verticals. They are only flush to the back, so all I did was tap them to fit. After that came the next layer. It was placed on top, glued through the mortice, then the longer (65mm) Dominos were driven in, like a nail. These then would stick out enough for the next layer. I drove in screws to pull it all together as the layers went on. After that pic was taken, I took the top and last row of verticals off and clamped it to dry over the weekend. Those parts were not glued yet. They were installed as a test-fit, to be sure the total height was correct. Sometimes nominal measurements don't all add up the way they should.
4)mostly answered with 3
5)These are shoe racks, for children. Those openings are very small, which doesn't show so well in the pics. They are about 7" high and 6 1/4" wide.
We do occasionally still do physical mail type cubbies, though they are not generally for actual mail, but internal paperwork. Trucking companies do it for drivers.
It was slightly out of square, but pulled right in when installing the back this morning. I forgot to take a final pic of it though....tomorrow.
Finished pics.
