Guy Ashley
- Feb 19, 2010
Rob-GB said:Frank-Jan, Thanks I'm not going doo-lally then [laughing] [laughing].
The 5mm with countersink does not show on the Festool UK site [sad]
Alex, I believe the self centering bit you called the hinge centreing bit is actually designed for cabinet work where the fittings drawer runners, hinges etc. are fixed with those stubby (short) screws, so the drill bit does not need to be all that long. It would be nice if Festool made one for ordinary door hinges, say for 3" and 4" butts, the ones available over here have too much slop in them and when the wood swarth gets packed into them(due to poor design) the bit snaps!
Rob.
Spot on Rob!!
I make and fit hardwood doors and the ones you refer to as snapping make me "Snappy" [tongue] when it happens on site as you spend an age digging the broken bit out, redowling the hole, redrilling it with a normal brad bit.
The springs go very sloppy very quickly even if only used on softwood frames so come on Festool, those of us who use your kit are giving you a heads up on a piece of kit that would be "snapped up" if you offered it.
Good chip clearance, strong spring, strong non deflecting drill bit, adjustable depth and a in a variety of sizes.
Too much to ask?
