jmbfestool
ART at WORK said:Hi
I have used the 420 now for about 8 hours, not a really long time and I now start to have a problem with the Strobe light.
It started off fine. I was very impressed by the blade standing still and the strong light.
Then by the last lot of cutting in 18mm birch ply the Strobe was out of sink. The blade was moving looked a bit like vibrating and the strobe was flashing when the blade holder was at the bottom of the stroke which causes a shadow over the blade.
Less visability.
Then I noticed the the blade wasn't stopping at the top anymore.
JMB mentioned this happening with his as he was having trouble getting the eject function to work " so you have to switch the carvex on and leave it on for a bit so it calibrates its self so when you turn it off it stops with the blade up so then you can then eject the blade."
How soon did this problem arise with your carvex JMB?
Has anyone else had issues with the strobe light not working. I tried pushing the blade back up to the top and starting a fresh. Only lasted a few moment before going out of sink again.
I will fiddle about with it tomorrow and see If I can get it working again. Try the turn its light on and then only strobe. Need the manual to check the sequence to do this.
Or its the send it back road I guess. As I keep saying the light was an important sales feature for me. If it f ed up after 5 years I would say ok but 5 hours is a little soon.
Pip
It pretty much started when I first had it. I also mentioned the light on another topic somewhere not sure if you read that one but I also mention about the light can actually be more of a pain than of any use. Like you mentioned it goes out of sink and u end up not being able to see where your going. The updated version of the 400 and I would assume the 420 you can turn the light off if you wanted to. I have the older older model and I can not. I first thought the light was amazing especially when the blade stood still but that pretty much never happens any more with mine.
When I try and show people I end up turning the carvex on and off 15 times or more to try and get the light into sink to show them a blade which looks like its not moving.
When it does happen I feel like touching the blade don't know why just I get drawn into the blade lol.
About the blade not stopping at the top..........
It does it if your battery runs flat
It does it when you hit something hard and you get bounced out of the work piece
It does it if you turn the jig saw of while still cutting
It does it when it feels like it.
JMB
