jaguar36
- Jul 19, 2011
That thought occurred to me last time I was polishing my carKev said:The RO is also a brilliant polisher ... [wink]
jaguar36 said:Could you post a link? I searched but the only solution that I saw was to check to make sure the bed and fence were flat and aligned (which I'll do when I get home). Everything else I saw was just other people who were also complaining about kickback.Ed Bray said:I would do a search on these forums for the Kapex kickback solution, it's easy to do, takes a couple of minutes and totally solves the kickback issue.
Also just to be clear I'm talking about "2) The blade grabs the small cutoff and rockets it straight back into the bevel gauge sending it ricocheting in an unpredictable direction as you contemplate the whole clean underpants thing again."
Ed Bray said:Found it, read the whole thread, it works.
http://festoolownersgroup.com/festool-tools-accessories/kapex-%27depth-of-cut%27-adjustment/
What pray tell are these so obvious advantages? (keeping in mind that as mentioned the dust collection and lightweight don't matter)roblg3 said:NO! If you don't see the obvious advantages it's not the saw for you.
Kev said:I think the point here is you don't need to buy a Stiletto hammer if you just want to smack cockroaches.
... You have a choice!
roblg3 said:My point is, if you don't see the advantages of the saw, you don't need them or use them. This saw does several things I don't believe other miter saws can. If you want to learn about your saw now that you own it, there's plenty of YouTube instructionals that can teach you. I tend to research my tools prior to purchase to make sure they will suit my needs once I decide to buy it.
