the dominos make for great poker chips at the next card game. and you can use your winnings on your next projects. If your good at cards you might never have to buy dominos. A win win situation to me, eh?Garry said:Uncle Bob is sending a Domino with all the other goodies. I should have it by Friday. I'm trying to find a way to justify this purchase, as I am NOT a pro. ???
I'm sure it will come to me. ;D
Garry said:Box on the doorstep Friday when I got home from work. I took the new toy out Saturday to play around with it, and today I made 2 picture frames from 1x6 cedar scraps I had. The Domino may be the coolest tool I've ever used. I love my TS 55, but this thing is just COOL.
So in barely over a month (since 9/7) I've ended up with:
TS 55
MFT1080
OF 1400 EQ
CT22
RO125
Domino
75" Guide Rail
Guide Rail accessory kit,
Domino Assortment (with cutters)
and lots of accessories for the items above.
I'm contemplating adding a DS 400 to the mix, and when my portable shop vac quit, I had a VERY hard time not replacing it with a CT Mini. (Ended up with a Rigid toolbox style) I think I need to seek help. ;D
Dave Ronyak said:But you won't regret the DS 400 either, which I understand uses the same abrasive sheets as the LS 130, or the RS 400 if you need to get into corners, which I do with the Deltex.
Eli said:Dave Ronyak said:But you won't regret the DS 400 either, which I understand uses the same abrasive sheets as the LS 130, or the RS 400 if you need to get into corners, which I do with the Deltex.
Other way round I think. The DS400 is delta, the RS400 is square, so RTS400 uses same sheets as LS130.
sw1211 said:I'm on that same slope, just haven't pulled the trigger yet. It's all justified in my mind, as soon as the back will let me in the shop again I'll be ready to start abusing some plastic. You can always fall back on, "life's too short." or x'mas present to self. My problem is I know I won't be able to stop at one. Enjoy.
