dragoneggs
- May 10, 2020
Using my OF1400 for the first time and trying to drill adjustable shelf pin holes. Read reviews on shelf pins being sloppy in general. Drilled some holes using my new Woodpecker template jig using a bushing and an Amana 1/4in spiral bit. The pins are a sloppy fit. Measured drilled hole right around 0.253in. Measured bit diameter about 0.249in. Is this normal? Do I have an unacceptable runout on my router? Or maybe the bit straightness out of tolerance?
Granted the pins are measuring in at 0.245in. What are you all doing to get snug fitting shelf pins?
