hobkirk said:
mhch said:
...The hose is attached using 40mm PVC clips that can be
opened/closed at will, although they are not meant for
it...
Where did you get the clips? Are they designed for large wiring bundles?
I found them in a well known DIY store here in France, in the PVC pipe department.
Several diameters are available, although I don't remember what they are.
I guess they are used to secure the pipes to the walls, similarly to those
brass devices used to secure brass pipes.
They are normally meant to be tightly clipped around the pipe, so it's not
possible to open them later. But if not clipped tight they can easily
be unclipped as needed, which is very handy to attach the hose to a
boom arm so it can be removed if needed.
I have no idea of what load they are designed for, which could be the major
issue to attach big wire bundles. but they are likely quite solid. I have some
spare ones and I can easily give it a try to see how solid they are.
