I'm sure all sortainer users can express sympathy with me on this one.
When the drawers are in the closed position, there is a lot of open space for bits to jump around, migrate compartments and change position so that you cannot open your drawer.
After you load up your drawers and go for a bouncy ride in your truck then attempt to access your contents you are forced to shake the heck out of each drawer to settle things down so you can actually get at them. Or you end up having to pry the levels apart and slide a feeler gauge in the top of the drawer to knock things around. This on a few occasions has been a major PITA. Under-filling drawers helps alot, but a sortainer is not space-efficient storage to begin with and filling drawers to 1/2 their capacity is very inefficient.
So how do we fix this?
Easy, take the drawers out of your sortainer, look in the slot and look at the top, there is an ABS lattice with big wide open compartments above the drawers. If this were solid then we be able to fill out drawers and never have to worry about not being able to open them later.
