Holmz - Fortunately, my guide track and saw base are both dead flat.
The Festool saw bases are made of cast aluminum or similar alloy and they sit completely on the guide track. The saw base is cast such that it has a lengthwise, male groove in the base that fits over a female, lengthwise extrusion on the guide track. Thus, the saw is guided by the interface of these two. The saw base has cams which are part of adjusting dials (2) which bear against the extrusion and these provide the user with the ability to dial out all slop in the fitting of the saw base to the extrusion. The saw base rides on two glide strips on the guide track. The saw therefore glides easily but the distance between the two strips is a bit less than the width of the saw base. Therefore, some rocking can be induced if there is no downward pressure on the saw against the base. Consistent, downward pressure eliminates this tendency.
rst - so, do you just use a ruler or other measuring device to position the guide track to cut to a mark, rather than the splinter guard?
JonSchuck - are you setting the toe with the adjustment cams? I adjust mine by pushing the base evenly away from the cams and then adjusting them for zero slop. Didn't realize there is a recommendation other than dead-straight
