Mario Turcot
- Nov 26, 2017
Hello all,
While I am almost done with the Kapex stand (missing a hadwood top) I worked on a swing boom arm to go with the CT-26. I want it to be able to accommodate the kapex, CNC and MFT without having to move the vac.
Here the prototype I came with so far
It is a very simple setup using a 1" electrical pipe (EMT). I will use an iVac switch at the CT-26 to power the vac and tool on a separate circuit. A 14ag power cord is running into the pipe with a wood plug to protect from wearing against the pipe. As you can see on the pict I have a receptacle (split) every two studs.
For those interested, the pipe bending specs are:
Beak - 25deg @ 6",
Neck - 45deg @ 30"
Leg - 45deg @ 54"
I have a CNC gcode file to cut the wall brackets made of BB 12mm doubled.
I'll post more picts tonight
Mario
Beak - 25deg @ 6",
Neck - 45deg @ 30"
Leg - 45deg @ 54"
Mario
