joiner1970 said:
Anyone know if you can buy the contents of the sys 1 box thats the one with all the multi coloured boxes in and foam bits. I have just picked up 3 Metabox sys 1's and would like to add inserts to them. My local shop is selling them for ?15 less than half what a Festool sys 1 is at the moment ;D ;D ;D.
Yes, you can get the multi-coloured boxes that fit into the SYS 1 BOX separately, with the following order numbers:
(All 63mm high)
Red, 54x54mm, 12 in pack, 487657. (Click
here for sample of item on eBay from Healy's)
Yellow, 108x54mm, 6 in pack, 487658
Blue, 108x108mm, 3 in pack, 487659
Green, 162x108mm 2 in pack, 487660
A soft foam eggbox style insert for the lid can be found with Order No 491640. This is called a "Dimpled cover pad" and designated "SE-DP SYS 1-4" in the UK.
A hard foam insert for the lid has Order No 491641. Called a "Hard foam cover inlay, flat" and designated DE SYS 1-4.
Forrest
