fdeloncker
- Apr 18, 2013
Just wanted to share a quick glimpse at how I modified my SysRoll without any permanent changes. I needed this because I do not have Festool drills (want em, dont have em), however I do carry my drills/impact in one sys2. I wanted my chargers ready to go all the time and wanted to use some of the wasted space on the back side of this. I also use the space between the systainers and plywood to bring in odd items to a job such as a paint poles, longer levels, etc.. I also needed a quick way to remove it so I could pull it up into my truck with ease and the T bolts with knobs do the trick. 1/4 turn and slide them up and out. I can still go up and down stairs no issue. A simple french cleat bolted to the lower and a matching angle holds it in place. (BTW, if you have no systainers on the cart or only an empty one, yes..it will tip backwards, but do it once and youll remember the next time
Enjoy, modify, have fun.
