Sysport build
DynaGlide said:
[member=73418]Jason Hagen[/member] They start at 16mm. Where did you see 8mm?
I'm guessing from the SYS-AZ instructions; they state ≥8mm on them for the bottom 5mm hole. Of course, 16mm is greater than 8mm...  [wink]
TSO’s plans also show 8mm.
I figured either I could just go with 16 or get to 8 in one of the following ways:
  • Start the panel longer and trim it after making the holes.
  • Shim the LR32 stops to start it at 8mm.
  • Manually locate the LR32 rail to get to 8mm.
I went with 16mm, because I wanted to be able to secure the rail with the end stops, then just flip it around for the next set of holes.
Usually, I’m the type to try to squeeze out every bit of usable space, but I didn’t think 8mm was worth fighting for.
