LostInTheWood
- Jan 23, 2011
Alex said:I would say I'm careful with my tools because I want them to be in good condition, but I'm not too concerned about cleaning them all the time, I only clean them when they're really dirty. Like when my Rotex is completely white because of the plaster I've been sanding or green from the 25 meter long barn I did. Then it gets a vac treatment and wiped off, but that's it.
Only thing I detest is paint on my tools, and I do mostly paint work, so when I sometimes get some paint on one of them I do remove that immediately.
I also buy a lot of used tools and refurbish them for resale, and then I clean them thouroughly, remove every spec of dust or paint I can see, and open them up and clean the inside and replace parts if necessary. It is amazing how good you can make used Festools look again with a good makeover.
I do this too. I like to run the tool full throttle while getting the vac nozzle on the intake and exhaust vents. I also vac the switches and shift knobs/buttons/levers and any other mechanical penetration. Once a year I do tool inventory and everything gets a serious check. Assessments are made to upgrade, repair, or replace. Tools that got heavy use get split open and I clean out the brush rings, coms, and fans.
