I am building a cabinet and cut domino slots in the sides and center divider to take the shelves. On the divider the slot went clean though; I was horrified that I had the depth too deep and was going through to the work table (my TS...); but then realized that the slots I cut into the right side were simply joining up to the ones I had already cut into the left side.
They are so perfect it is like one slot. It is an expensive machine, but apparently worth it; I wouldn't have thought it was possible to get it that precisely if I hadn't done it.
Anyhow, I hadn't expected this to happen, and now I don't have enough depth for two dominoes. The wood is 17mm and the dominos are 30mm. I can either just stick one in the center and have 6mm sticking out on each side, or I can cut deeper slots in the shelves and have each domino in the center 8mm. Neither is a great solution, but the first is easier. Whatcha think?
