Thinkin bout a Domino !!
JerrySats
I've seen people talk about the older version with metal pins , what does this refer too and is it something to look for in buying a used one ?
Jerry
I bought my Domino when the big recondition sale was going on.
It's the pin style.  I have seen videos of the new style.  Just by the looks of it, I'm glad I have the pin style.
But I'm know a guy with the paddle style is going to say you need to buy a new one with the paddles.
I like the pins because I believe they retract better.  Plus, they are made out of metal,  not plastic.
And if you're thinking about buying a Domino, then you have the money too buy it.    SO JUST BUY IT  [big grin]!
You will not regret it.  Like every one else says,  it is a game changer.  You will look for ways to use it.
I am so glad I bought mine.
Eric
I wouldn't dismiss a domino with either the paddles or the pins.
If you find one and come to terms, purchase it.
The paddles are retractable and that's a nice feature.
The pins can push the work away, as can the paddles, once the paddles
are retracted the domino is easier to work with.
Good luck Jerry.
[big grin]
Paul Marcel is a very savvy woodworker who is well endowed with common sense -- be sure to watch his videos.  [thumbs up]
I have both models and I like each for different purposes.  Does anyone NEED both styles?  Absolutely NOT!
If I had to decide to sell one & keep the other I would probably sell the paddle version (today).  Ask me a month ago or a month from now and I quite possibly would answer differently.  (How helpful is that advice???  [huh])
I too am considering a domino.  I currently have a horizontal slot morticer attachment on a minimax combo machine, however, I've never used it because I just can't imaging accuratly forming mortices with it.  It appears I'd have much better luck with a domino.  My dilema is which one?  I'd love the ability of the 700XL, particurally in light of the fact that my 1st project with it would likely be joining very large boards in a workbench.  But can it be reasonably expected to do the work of the smaller (500), i.e. - face frame joinery?
The DF700 is definitely not for face frame joinery, unless it is thicker than "normal" stock.  I use 6mm dominos in 3/4" stock, which are only available for the DF500.  The DF500 will cut up to10mm thick domino slots, which can be stacked in thicker stock, but the tenons are limited to 50mm long overall.  The DF 500 dominos range from 4mm to 10mm thickThe DF 700 will cut mortices from 8-14mm thick and 70mm deep.
Festool has a Domino mini site and this page shows a comparison of most of the key specs:
http://www.festooldomino.com/mortisers-joinery/models/comparison/
I can't believe there is so much opinion over the pins/paddles.
Mine has paddles and I usually just keep them retracted.
The pin one made everyone go overboard on cutting mortises every 3".....
So, I prefer to have neither on the fence.  For the big work, I just use my Festo chain mortiser.
Same here although I don't have the Festo chain morticer but I'm thinking XL [smile]
+1 Don't use the paddles. Permanently retracted them.
The smaller domino would be most suitable I think.
Have one and luv it. I just used it today to attach a teak threshold to an oak floor without a T&G Great tool and I have forgotten the cost side of it. Mostly  [cool]
I have a Mini Max mortiser too.  It is in the barn since I got the original Domino.  It works, but it is so slow to set up and actually use, I can get out the Domino, cut the slots, and put it away again in less time than it would take to set up the MM mortiser.  I cannot help you with your decision as to which one to get though.  I bought both in a fit of cash burning a hole in the business pocket.  [laughing]  Seriously, I use my little one all the time, and I have need of the big one on occasion.  I also got a great deal on a Powermatic floor stand mortising machine, but it has been sitting motionless, and especially so since I bought the large Domino.
