idratherplaytennis
- Jul 6, 2015
I wasn't sure if this should go here or the other tools section, however since I am considering the Festool versions, I figured this was a good place to start. I've had the Makita track saw for awhile, primarily used it for sheet good break down, scribing cedar fence posts so they fit nice to crooked buildings etc, and loved it. Clean cuts and amazingly precise sharp lines- yea yea, I know- not Festool, but I purchased it before I could afford the green and now I can afford the green.
I have a question regarding the power and quality of the Festool, as it compares (to the Makita) and to see if anyone else has had a similar issue I recently came across. I have the potential option of selling my Makita to a guy I work with that is impressed with the "track saw" in general and it's abilities hence my foray into this search. From reviews I've read, the Makita and Festool are the two ways to go, with the Makita boasting more power, more so, apparently than the TS 75- as far as wattage is concerned. That's not my primary issue. For sheet goods and the like, I'm not concerned, as I know both are winners. It's more of when I get to slightly thicker stock, such as some doors that we recently hung in an apartment, replacing old doors and having to scribe them in to fit the slightly less-than-plumb doorways. When trying to rip the length of the doors (top to bottom) I noticed blade deflection, forcing me to constantly plunge and re-plunge my cuts to power through the door length while shaving anywhere from 1/16 to 1/4 off some doors (sometimes an even cut across the cut, sometimes it scribed from 1/16 to 1/8 or 3/16). I'm potentially chalking this up to the fact that I haven't changed the stock blade yet (I didn't want to deal with changing the splinter guards to the new blade, however I have the new guards and new freud blade... that and the current blade is still pretty darn sharp that I wouldn't run my finger across a tooth).
I was just wondering if anyone has come across this issue running a TS55 REQ through thicker stock when they just want to shave a little off of something, if that could be a blade issue or if using a TS75 would be the remedy. I'm 95% certain I will be buying into a Festool track saw, it's more of the cost of the upggrade and timing. It took a long time to rip down the doors to acceptable finish levels (these were cheap hollow-core mdf veneered interior doors with wood framing) and even then, they required plenty of after-sanding to remove some blade marks due to the deflection and re-plunges.
Also- before anyone even asks, this happened at basically every feed speed and I know from all the tile work we do, if the blade kerf is too thin, or you push too hard, the blade won't track back to straight unless something breaks or starts fresh- this was more of an "it just kept happening no-matter-what thing" and I'm just glad I wasn't doing hardwood stain-grade solid doors.
I have read countless pros and cons of choosing the TS55 REQ to the TS75 but from the sound of things it usually boiled down to two things- 1, If I don't mind the extra weight/size and 2, The depth of stock I normally cut. The two things I didn't understand so much was the fact that the rpms are vastly less on the 75 than the 55 while the power is higher, unless that rpm is off-set from a greater tooth-count or some other variable I'm not catching onto.
