treesner
- Sep 1, 2015
Is it just me or was the bevel cut feature of the track saw under thought? When you tilt the saw to 45* it wants to wall over so right off the bat the balance is off and required one hand holding down on the saw guide (if you want to move you risk the saw tilting and messing up the cut in that area. It seems like they could add some kind of lock feature to the track saw that it doesn't want to tilt off the track. Also I found that what is marked as 45* on my saw is slightly off, i had to recut all the bevels on my box with the saw set to slightly over 45 to get a more seamless joint.
