sancho57
- Jan 13, 2011
Since they do not allow the TS module to be used in the states and I dont have a TS 75 mounted in my CMS I have found that yes the blades make a difference. My question for you is why not just go with a TS 75 in the CMS. It has plenty of power to cut anything you would possibly need to cut.I have both the TS 55 and TS 75. The TS 55 I use for cutting sheet good and thinner timber. The TS 75 which is not mounted in my CMS I would use for ripping thin strips that are not practical or easier then using the rail and for thick heavy hard woods and other work the would be better using the 75 for.
If you are in NA i would look at a good job site table saw rather then doing what I did which was buy the TS 75 module and TS 75 with the accessories, side table and CS 50 fence. For the price of all that you could get the saw stop job site saw.
Anyway just a suggestion
