I have another question along this line. I have problems cutting a 45 degree bevel in veneer core plywood with the 48 tooth blade with my 55. The saw struggles and burns the ply. I have to use the 28 tooth for bevel cuts. I don't know if it's simply the greater thickness (26.87mm vs. 19mm) or the fact that it's cutting the ply at a bevel. I tilt it back up to 90 and cuts the same ply with the 48 tooth blade with no undue struggle.
Am I the lone ranger in this?
