TS75 Saw Blade Widths
NVA_WW
Hi Folks - I'm planning to buy a new fine tooth blade for my TS75.  I still using the original blade and I decided it's time to get an additional blade.  Is the width the same for both the fine tooth and universal blades?  Need to figure out if I will also need new splinterguards on my rails.  I do like the new clear splinterguard.  It came included in my new LR32 55" rail.  I'm trying to figure out if this new splinterguard is also standard on all new rails.
On the TS 75, the kerfs are the same for the following blades:
  • Universal - it comes stock with this blade
  • Fine Tooth
  • Solid Surface / Laminate
  • Aluminum / Plastic
The translucent splinter guards are standard, now. They may not be on every guide rail you buy, however.
