They used to make a CMS module for the AP85, so I expect them to release one for the HK85 as well.
No, he's missing the Precisio
Well, all things relative. If you cut things at an angle, the spring tension distracts more from safety than it adds.
Kev said:chappardababbar said:I now have three festool circular saws:
TS55 for sheet work, and for use in the CMS module for finer cuts on a table saw
HKC55 as the cordless, go anywhere saw
HK85 for the extra depth that the TS55 and HKC55 can't do, plus I think it means I can avoid having to get an OF2200 for dados.
Cordless. Fine sheet work. Thick work + dados. All bases covered?
Got the HK85 rather than the TS75, because I don't think I need 75mm depth on a table (in CMS), TS55 will do fine in CMS, and HK85 can do greater depth on a rail PLUS it has the dado ability.
Let's see how it goes...I do feel like i have one saw too many
Nah!! by my reckoning you have 2 too few [wink]
TS75 pretty much lives in the CMS module, but it's ready for the big clean cuts when you need it.
TS55 (early version) which I feel gives a better mitre accuracy and is the sheet goods weapon of choice.
TSC55 because it's brilliant for the odd jobs and gives great freedom with the dust bag.
HKC55 as it makes messing about away from power with the FSK rails a breeze.
HK85 with the grooving unit because it's a beast.
So ... my thinking is that if you have the 5 above, the one you don't need is the corded HK55 (as you have that option well covered)
Alex said:Coen said:Alex said:festy said:I've read all I can find regarding the HK85 and watched the small selection of videos. It appears to be an extremely versatile saw that does everything the TS75 can and more. Does the HK85 make the TS75 redundant, or am I missing something?
Yes, you are missing something and I am surprised nobody above mentioned it yet.
The TS75 is a plunge saw while the HK85 is not.
But look at this;=4m18s
[eek]
One of the characteristics of a plunge saw is that is has a spring that makes it go up again once you let it go. Important safety mechanism.
Of course you can plunge with any circular saw, but it does not work as smoothly and safe as with a real plunge saw.
