tjbnwi
- May 12, 2008
jimbo51 said:I think that an obvious step would be to discount the Variable angle "set" so that buying the triangle and the adjusting bits together is cheaper than buying the two items separately. Festool often uses this approach.
I doubt that using acrylic would be only 30% the cost of aluminum. Part of the cost is paying down the investment in the R&D. The material used has no influence on that cost. When actually taking the tool to the work etc, I can see that acrylic might have durability issues.
The video on the large octagon did not teach me anything about the accuracy/precision of the system. I knew that the tool would be very good and that is all the video showed. I would like to know if the tool is extremely good and worth the high price. Because the fitting was done on an uneven surface and parts could not be carefully aligned, I could not determine how good the fit actually was.
Perhaps a follow-up will show how the pieces fit together on a good surface.
At least I was not the only one who thought the initial website presentation was not optimal.
Sorry, that octagon is long gone.
I had enough confidence in the prototype that I laid out this counter top.
