Jeffonebuck Member Joined Feb 1, 2015 Messages 41 Feb 2, 2015 #1 My first question might be an old thread but instead of googling I will ask. How well does the rail grip to UV coated plywood, Formica, etc. ?
wow Honorary Member Member Joined Nov 14, 2013 Messages 3,575 Feb 2, 2015 #2 [welcome] to the FOG! I can't answer your question, but I'm sure someone be along shortly to do so...
G getyourbone Member Joined Sep 7, 2007 Messages 46 Feb 2, 2015 #3 formica...very well in my experience. Have cut a number to countertops and never had a problem.
tjbnwi Member Joined May 12, 2008 Messages 7,064 Feb 2, 2015 #4 The pre-finished plywood can be an issue. I use the Gecko with the rail adapter. Tom
F fshanno Member Joined Sep 20, 2007 Messages 1,064 Feb 10, 2015 #5 I had it slip one time on prefinished ply and that was enough. I always clamp or use the parallel guides. Don't know about laminate.
semenza Festool Moderator Festool Moderator Joined Jun 24, 2007 Messages 10,365 Location Fingerlakes Region NYS Feb 10, 2015 #6 I haven't had any trouble with it slipping. Make sure the dust is brushed off the grip strips and the plywood is on something that supports it well. Seth
G G3Trim Member Joined Dec 19, 2014 Messages 48 Feb 10, 2015 #7 Not to change the subject, but how durable are the uv finished plywoods? Do they scratch easily when handling them?
F fshanno Member Joined Sep 20, 2007 Messages 1,064 Feb 11, 2015 #8 G3Trim said: Not to change the subject, but how durable are the uv finished plywoods? Do they scratch easily when handling them? Click to expand... They scratch. Wipe-on poly makes light scratches disappear.
G G3Trim Member Joined Dec 19, 2014 Messages 48 Feb 11, 2015 #9 Ok thanks for confirming my fears, fshanno.
WoodWhisperer Member Joined Jun 25, 2013 Messages 175 Feb 12, 2015 #10 Lam. Counter tops not too many problems. Pre-finished ply can be a problem. I always clamp or use with the gecko. Pre-finished ply is great to work with. It can scratch but just normal machining like running through the table saw its ok. Sean
