guybo said:
Michael Kellough said:
.JINRO said:I just ordered SE1 and SE2. I couldn't find pump for sale anywhere... but thanks to FOG members I can use different pump to work with it.
-Upon reading this thread, looks like "Vaneer Excel 3 Pump" works with SE units. Is this the site I can make purchase? (https://www.veneersupplies.com/products/Excel-3-Continuous-Run-Vacuum-Press-System.html)
-Is "Excel 3" 120V? or 240V?
-Is "Excel 5" too powerful? it's 5.0 cfm.
-Thankfully one of the member in this thread listed extra parts I will need for the setup. Is there any instruction video or steps I can follow for setting up SE1 and SE2 with this pump?
I can't wait to use them for my shop and thanks for making this work guys!
Domino11 said:...Connecting the Vacsys setup is no different. 100% Plug-n-Play.
 I added some more questions regarding Veneer pumps. Are they all 120v for US use?
.JINRO said:Domino11 said:...Connecting the Vacsys setup is no different. 100% Plug-n-Play.
Thanks so much for detailed explanation!I added some more questions regarding Veneer pumps. Are they all 120v for US use?
Excel 5 seems only $50 from Excel 3. I guess I'll go with 5
Domino11 said:
Forgot to mention these Excel pumps are super compact, quiet and light weight. Little Pocket Dynamo.
 Total cost of SE1+SE2+Pump came out similar to Set combo from Festool. Now I'm all set with Festool collection! (yeah right...)
Just Ordered Excel 5!Total cost of SE1+SE2+Pump came out similar to Set combo from Festool. Now I'm all set with Festool collection! (yeah right...)
Thanks so much for your help! Would you mind if I reach out to you when I have any question setting them up?
Domino11 said:Have confidence, my dude. You have everything you need to figure out how to do this yourself. Once the parts are in front of you it will become quite obvious.
 Quick question, do you know if I can get 4x4 vacuum head custom made anywhere? I deal with small wood crafting many times.  Smallest I see for alternative head is 200mm x 60mm.
 Quick question, do you know if I can get 4x4 vacuum head custom made anywhere? I deal with small wood crafting many times.  Smallest I see for alternative head is 200mm x 60mm.JINRO said:Domino11 said:Have confidence, my dude. You have everything you need to figure out how to do this yourself. Once the parts are in front of you it will become quite obvious.
Can't wait to receive my set!Quick question, do you know if I can get 4x4 vacuum head custom made anywhere? I deal with small wood crafting many times. Smallest I see for alternative head is 200mm x 60mm.
JINRO said:Quick question, do you know if I can get 4x4 vacuum head custom made anywhere? I deal with small wood crafting many times. Smallest I see for alternative head is 200mm x 60mm.
Cheese said:JINRO said:Quick question, do you know if I can get 4x4 vacuum head custom made anywhere? I deal with small wood crafting many times. Smallest I see for alternative head is 200mm x 60mm.
Make your own adapter from some plexiglass, phenolic or sealed MDF. The bottom of the adapter fits whatever head you want to use while the placement of the foam weatherstripping on the top of the adapter mimics what ever small piece you're crafting. A hole in the middle of the adapter completes the task.
 I guess I'll use some plastic plate cutout in shape of oblong head and hole out the middle in 4 inch diameter.
DynaGlide said:You'll have to make up your own hoses and fittings but yeah you can connect whatever vacuum pump you bought to any vacuum clamp.
https://www.veneersupplies.com/products/Podz-Vacuum-Clamping-Jigs.html
These are 4"x4".
You just need a way to couple from european high flow fitting (on the pump), using a quick connect, to whatever hose you adapt to work with the clamps.
zachjowi said:Michael Kellough said:
I ordered the SE1, SE2, pump combo but only receive the pump and SE2 today. I hope I am getting the SE1 that I already paid for and need the foot pedal from.
I'm in the same situation. I ordered the complete set with the accessory set and MFT clamp. I received the pump, SE2, and accessory kit, but not the SE1 and MFT clamp. I emailed BIS asking if I would be receiving the SE1 with foot pedal, and if not, what is their return policy. I have not heard back from them yet. My order was placed on 12/21/21.
