Oke, just tuned-in on this topic....
I work for a comany named Becker. we are the inventor of the rotory vane vacuum pump.
I'm the head of service and technical matter within Belgium Netherlands and Luxembourg....
But enough about me!
the deeper the vacuum level, mbar, the stronger the grip. This is correct. But.....
all leakage will drain your vacuum so piping and hose connection are important.
I noticed the remark, that oil lubricated pumps blow out oil... than you are dowing it wrong!!! oil circulation speeds up when vacuum levels is boulding up. oil lubricated pumps need to work on max. vacuum level. when the max vacuum level is NOT reached oil circulation and pump effort increase. the internal oilcircualtion system is not build for draining maxx oilflow and starts blowing exessive oil. because of the oil, all components get a almost zero clearance so almost absolute vacuum can be reached.-0mbar ab. or 1000mbar rel. perfect for what you want.
the use of a softstarter or frequencyconverter protects your pump against the kick-in of electicity. this will damage your pump within a year.
oil free pumps, not so deep vacuum level but for your use oke. so much to choose from.
the deeper the vacuum level, the less flow. sow check for this!
for both pumps, make sure a vacuum savety valve is installed in, or externall with your pump.
when the max. vacuum is reached, flow almost stops. this means no more cooling of your pump internal.
vacuum pumps create hot exhaustair, dust in woodindustry, hot running pumps and poor maintenace, do i need to mention..... so a hot running pump because pulluted filtration lack of flow sawdust and so on, check it.
Filtration, put a pre filter between the vacuum connection and this will als save your pump.
maintenacen is crucial, replace your filters on time, keep bearings lubricated and check pump internaly. prefenting damage.....
Any further question, let me know.
money..... what ever you want just be save. invest in what you can affort. Goog luck!!!
