Jesus Aleman
- Nov 12, 2008
I'm in the market for a drill. I already have an 18V impact driver (that I love) and a circa 1970s single speed corded drill that my wife won't let me dispose off. I have looked at the new drills (T15+3), but the price point may be difficult to justify even when looking at this on the long run (this is a hobby). The TDK12 set is being discontinued and currently being sold for $300 and change with the eccentric and right angle chucks. For $300 I do see value on the features and the chucks. However, I have read a few threads in the FOG that may indicated that the TDK12 is underpowered and the nickel batteries don't last long or hold the charge well. I can give you two reference points on my type of use:
1) I use the drill/drivers primarily on the weekend. My 18V impact driver batteries have sat in the garage for the entire Canadian winter and they are still holding a significant charge in the spring when I pick them up again. (I don't keep them in the garage anymore). Can I expect the same thing from the TDK12 batteries, or at the very least that there will be some juice left when I pick them up on the weekend after sitting idle for the week.?
2) Does the drill have enough power for locations where I cannot use the drill press? Most holes that I drill are under 20 mm (a notch above 3/4"). Depth is variable:
1-3.5" deep in hard, softwoods, man made materials, and construction lumber (4x4').
1/4" deep in aluminum
.. and sometimes small diameter holes (1/4"-1/2") in concrete blocks
I would use the TDK12 primarily for most hand held drilling operations, and for driving where the impact driver can't reach (eccentric and 90s). Is this a good investment @ $300 or should I look elsewhere. T15+3 ... very sexy, but hard to rationalize the price. One more question, I have a collection of 1/4" hex shank bits, would these work with the TDK12?
Thanks in advance for your feedback.
