Vecturo and a Track?
3PedalMINI
Hey guys, need a vecturo for a project coming up, Im modifying a Restoration Hardware cabinet for a TV lift and need to cut the top out for the lift. The easiest way with the least amount of kerf is to use the vecturo. Looking it doesnt look like i can use the plunge adapter with the festool track?
Anyone used the vecturo with a track? I dont want to use the TS55 because of the blade kerf
TIA
I have used my track as a straightedge to guide both my Vecturo and also previous Fein with the tool handheld.
You could use the plunge base alongside the rail after measuring the offset of course.
Are the cuts good and straight? I have no doubt that they would be but the depth of the top is 7/8" .....does the vecturo deflect at all?
Thanks!!
If the wood is hard it will deflect for sure. You should score a line to help start the cut off as well. You will need to be very patient to get a clean cut but i am sure you will have some sanding or hand planing to do either way.
Maybe the vecturo isn't the best option for this.
What's the smallest router cutting bit I can get? Thinking this is my best and safest option!
Preferably 1/8" cut but it doesn't look like this is available.
Any ideas? Thanks!
[member=17435]3PedalMINI[/member]
In your OP, you mentioned the "least amount of kerf."  The saw kerf on a TS55 is 2.2mm or .087"  which is less than the 1/8" (.125") router bit.  If you are looking for less kerf than that, Tenryu makes a .063" kerf saw blade (that comes with it's own riving knife) for plunge cut saws.
Mike A.
just as a thought, jigsaw (e.g., Carvex) can be used with a rail.
It is not clear if the least possible amount of kerf is a "nice to have" or a requirement. Are you going to attach the area which you will be cutting out back to where it was after the work is done?
My experience with the Vecturo and plunge base is that you will get deflection particularly along a long cut.  And particularly on thicker materials.  7/8" is probably pushing what the Vecturo can accurately cut.  I've tried it with 1" material and did not find the cut to be 'furniture quality' along the cut and depth.  You might try one of the round blades with the blade plunging against a 3/4" piece of wood along the cut as an option to give you both more width along the cut and a flatter surface to reduce deflection.
My personal choice would be the TS55.  It will give you an accurate cut with zero deflection.  You will need to finish up the ends, but that could be done with a Vecturo or a jigsaw or even a handsaw.  Might need some sanding or a rasp to finish it off.
You will very likely get deflection with a 1/8" router bit, most noticeable as you go deeper into the cut.  From the collet to the end you may have as much as 1.5 to 2" of distance on the bit, which I expect would likely deflect.  Plus a 1/8" bit won't give you a quality cut if it's meant to cut 7/8" deep, even with multiple passes.  With a 1/8" bit less the depth of the flutes, you don't have a lot of metal.
What is the size of the opening you are cutting?
