VECTURO multitool and TSC 55 cordless saw photos and details
GPowers said:
LesJ said:
I have the Fein supercut and have just bought the DeWalt version. The variable trigger on the Dewalt complete with DA and light really do make it stand out. Interesting times
Do not forget the Dewalt "Quick Change" blade system. it is a lot easier then the Fein where you need to remove the pin.
Surely its not that hard to remove a pin. I've never found it hard to do ,takes me seconds to swap a blade on my multimaster
I had a look at the dewalt and it is super fast to change the orientation of the blade, very nice
I always have the fear i'am going to drop the pin and loos it. Dewalt new quick change solves this with the open ended blades.
When you look at, Dewalts solution, it seams very obvious, and you wonder why it took so long for some one to make the change.
jmbfestool said:
Been told the cordless TS saw dust bag isn't just a normal dust bag it has something making it better?????
Maybe some kind of fan to create a bit of extra airflow? Like a small built-in vacuum?
All shops publish the pictures of the BHC since ½ year.
But on Slingers it says: "NEW (Delayed until Spring 2014)".
We have to be patient.
GarryMartin said:
joiner1970 said:
I only thought about it the other day when I saw someone on here showing off their stack.
If you're on Twitter, search for the #stackfest hashtag. We had quite a competition going at one point...  [big grin]
https://twitter.com/search?q=#stackfest&src=typd
I checked the link and somehow my 4 metre stack doesn't seem quite so great anymore. Had to post this pic as it's so ridiculous. (Sorry if it's a repost ?)
[attachimg=#]
Yeah I saw that photo over at twitter. I followed Garry's link but I never know what I'm doing on twitter I prefer Facebook much easier to understand lol
Yeah... not sure how I missed the #stackfest to begin with. We had something similar happen on our Facebook page last year. Need to tag me in on this kinda stuff, Garry.  [wink]
Will do.  [wink]
The #stackfest photo above belongs to Chris Rhodes. He's posted an alternative view on your Facebook page! Rumour has it he was moving to larger premises with a higher roofline to better his entry... [blink]
Just found this on a web site ( hauler.ch) showing prices in Swiss francs. The 561696 which is 2 batts and 2 chargers in a t-loc no rails for £769,57
FE561696 561 696 TSC 55 REB-Plus/XL Li 18/36 4.2 2650-3800/5200 160 27/36 -1-47 0-55 0-43 4.6 / 5.3 10000 1 1'133 .00 = £769.57
hasler.ch> Apparel > Machinery Power Tools > Sawing Cutting > Circular Saws > FE10050
Cordless track saw TSC 55 FESTOOL
Our best track saw makes now independent.
Strengths and benefits
Brushless EC-TEC motor combined with lithium-ion batteries for maximum cutting performance
Flexible dual battery concept: Operating with two 18 volt battery packs (36V) for maximum performance, or with a 18 volt battery pack possible for light weight
EC-TEC motor with high speeds for perfect cutting quality and fast work progress
Dust collector bag for emission-free work
New FastFix generation for even simpler and quick blade change and material-specific working
Main applications
Precise plunge cuts up to 55 mm material thickness
Perfect cutting of interior doors - guide rail with plunge-cut saw
Sawing recesses in doors and kitchen worktops
Included 2 Battery Pack Li-Ion 4.2 Ah charger TCL 3, HW fine tooth saw blade W48, dust collection bag, anti-shatter, window, operating tool, in Systainer SYS 5 T-LOC
FE10050 Accessories
Orig No.
Type
Battery voltage
V Battery capacity Li-Ion
Ah Idle speed
min-1 Saw blade Ø
mm Connection Ø
mm Angle range
° Depth of cut
mm Cutting depth 45 °
mm Weight 1x18V/2x18V
kg Weight
g Package
Piece CHF excl VAT
per piece
Piece
FE561679 561679 TSC 55 REB-Plus Li 18/36 4.2 2650-3800/5200 160 27/36 -1-47 0-55 0-43 4.6 / 5.3 9500 1 1'058 .00
FE561700 561700 TSC 55 REB-Plus/XL-FS Li 18/36 4.2 2650-3800/5200 160 27/36 -1-47 0-55 0-43 4.6 / 5.3 0 1 1'201 .00
FE561704 561704 TSC 55 REB-Plus-FS Li 18/36 4.2 2650-3800/5200 160 27/36 -1-47 0-55 0-43 4.6 / 5.3 0 1 1'133 .00
This the price of the dust bag on it own 46 Swiss francs, seems cheap can't be much to it for that price.
Accessories for TSC 55 FESTOOL
Main applications
The dust collection bag ensures a emssionsarmes and clean working environment with maximum mobility
Supplied packed for self-
Fits
for TSC 55
FE10051 Use in
Orig No.
Type
Weight
g Package
Piece CHF excl VAT
per piece
Piece
FE500393 500 393 SB-TSC 1 1 46.50
[attachurl=#]
They also have the vecturo prices, and some good close up photo but don't seem to be able to put on here may be some one Else might able to do it.
Oscillators OS 400 FESTOOL
Equipped with the end decide more function: accuracy.
Powerful 400-watt motor with electronic speed control for consistent fast work progress
Ergonomic: The slimline shell with rubberized grip fits perfectly in the hand, the switches are ideally positioned
More accuracy with the depth stop: Easy adjustable without tools. Just saw the teaser: The Ansetzhilfe. Ideal for excerpts from delicate surfaces
Flexible use, short setup times: The VECTURO is by plug-it cable ready to use. Knives and accessories to be changed without tools
Organization for every application: saw blades, spatula, and accessories can be handy sort in SYSTAINERS
Perfect in the system: Universal Bi-metal saw blades, special blades for GRP material and non-ferrous metals, filler for adhesive residue and silicones
Main applications
Notches, cut-outs and plunge cuts in wood, composites, coated materials, even in hard to reach places
Removing glass from windows, removing silicone, adhesive, grout or Fensterkit
Cutting skirting boards, beams and profiles of all kinds; cutting of door frames and pipes
Delivery Ansatzhilfe-/Tiefenanschlag-Set OS-AH/TA Set, In Systainer SYS 2 T-LOC
FE10046 Accessories
Orig No.
Type
Input
W Power output
W Vibration
min [-1] Amplitude
° Cable length
M Weight
g Package
Piece CHF excl VAT
per piece
Piece
FE563008 563008 OS 400 EQ-Plus GB 400 220 11000-18500 2 4 1000 1 638.00
FE563009 563 009 OS 400 EQ-Set CH 400 220 11000-18500 2 4 1000 1 867.00
[attachimg=#]
Maths puts mine a little more than 18m, but I'd never be game to try a tower [blink] [eek] [scared]
[attachimg=#]
Do it do it do it do it lol
That puts my 3.5m to shame
joiner1970 said:
kostello said:
Peter-kenny said:
Soooooo can somebody give me a idea when the vecturo be hitting the dealers shelf???
I cornered the festool rep at Isaac Lord last week and he said April
That would make sense as I know a certain dealer is having an open day in April :)
The Vecturo will be launch in May, it's just the cordless TSC & SDS coming in April.
