smorgasbord
It's in German with, for me, English sub-titles. It's a bit slow, but you get to see the first joint cut with a Domino, back in 2004/2005, on a garden chair, apparently not glued or at least not glued well.
The meat of the video starts about 5 minutes in, when he describes the changes to the Domino and the motivation behind them.
My summary:
• The original pins were quickly discontinued because they'd get stuck. This would happen if you cut something just glued or resinous woods.
• The paddles have some play, but since you're always pushing on them the same direction, the play is taken up the same amount every time. The play prevents sticking.
• The original lock levers would wear and the handle stick out. Fixed by disassembling and reassembling one hex nut notch over. The new levers are spring loaded, so no disassembly needed.
• The paddles can be locked out of the way with a small hex wrench on a screw if you're not going to use them for a while.
• Some fence improvements were taken from the DF700, such as a more robust column guide, moving the height clamp to the left (same side as height guide).
• Cordless is a big improvement since the dust hose swivels and doesn't tangle, but the power cord did and would wrap around the hose.
• D-handle enables you to push in line more easily.
This is his personal channel, which seems mostly about a van conversion he's been doing.
PS: Peter Millard linked to this video in his latest video.
