So, [member=61691]TSO_Products[/member], can I infer then from your above explanation that the FS-WA/90 is fully compatible with TSO's "TPG Parallel Guide System" and that it (the FS-WA/90) also provides the same functionality (the functionality which allows the GRS-16 PE to mount to the MFT/3 guide rail hinge bracket) when used in conjunction with the MFT/3?
You alluded strongly in the last paragraph of your response
here to the exciting potential that this setup provides, at least as it relates to the GR-16 PE. Further, one can witness this potential at play, again as it applies to the GR-16 PE, by viewing the images which appear
here,
here,
here and
here (the last two depicting the setup for someone who is left handed).
However, while I assume, from examining photos of the FS-WA/90 - a TSO-licensed accessory which appears to include the identical six threaded mounting holes that are a feature of the GR-16 PE (in the case of the latter: four intended for the installation of your parallel guides - left or right depending upon which end of the cut the GRS-16 PE is mounted on - and the two remaining for mounting the guide rail square directly to the hinge bracket on the MFT/3) - that the FS-WA/90 is identical in every way (not including the livery of course) to the GR-16 PE, it would be nice to get formal confirmation about this from the patent holder. The discussion
here comes tantalizingly close to answering this question but falls just short of doing so. Hoping you can clear this up for me.
On a related note, two years and almost seven months have elapsed since you divulged on the forum the potential of attaching a GR-16 PE guide rail square to the MFT/3 hinge bracket and, for the right-handed among us, attaching a "right" TPG parallel guide to the guide rail square to allow for repeatable and accurate cross cuts (when used with a flip stop(s)). I understand that you got the idea from a UK user. And, yet, it doesn't appear that this technique has caught on. A quick web search produces scant evidence or people having adopted it. Since it looks to me like this technique addresses all kinds of shortcomings with the MFT/3 (and lines up nicely with my desire to own tools which have multiple purposes and uses), why are we not hearing more about this? Is there more to the story? IOW is this not the panacea that it appears to be?
I look forward to your reply.
