What are these additional holes on TSO GRS-16PE?
TinyShop said:
TinyShop said:
So, [member=61691]TSO_Products[/member], can I infer then from your above explanation that the FS-WA/90 is fully compatible with TSO's "TPG Parallel Guide System" and that it (the FS-WA/90) also provides the same functionality (the functionality which allows the GRS-16 PE to mount to the MFT/3 guide rail hinge bracket) when used in conjunction with the MFT/3?
[member=64030]TinyShop[/member] - help me understand which country are you located in?
In response to your question: The FS-WA/90 made by FESTOOL in Germany under license from TSO is functionally equivalent in every respect to our USA made GRS-16 PE Guide Rail Square.
Hans
[member=64030]TinyShop[/member] : has TSO answered your question?
if not, let us know by emailing directly to
info@tsoproducts.com
attention Hans
attention Hans
Thanks Hans! I just knew you would come through. :)
So, yes, that answers my primary question.
My other question, which requested some insight on whether or not your customers are adopting the technique of installing the guide rail square on the MFT/3 hinge, was responded to by some existing customers of yours (folks I tagged). So, I think I'm good there too. In short, I'm now planning to pursue the technique myself since I think it will pay dividends in my work flow. I just wish I hadn't overlooked it until now.
Thanks again!
