Michael Kellough said:
Crazyraceguy said:
DynaGlide said:
Crazyraceguy said:
Coen said:
I already had the one on the right. It is the one with the modified zero degree base. I keep it set-up with that 3/4" diameter, 1" cut length bit in it for wood edging trimming. Getting that set perfectly takes some time, so I just don't mess with it very much. The machine is very precise and the base plates are very repeatable. So I can swap between the zero base with one bit and the 1.5 degree with another bit and expect it to cut perfectly after doing that, but I don't really want to push my luck beyond that.
I just thought it would be nice to have another one to use with a vertical base too. One came up on the forum classifieds at a reasonable price, close to me. So my router obsession continues. Now I need to rearrange some stuff to give it a space.
If I was doing this for a living I'd do the same.
A lot of what I do would be considered excessive, part of it is admittedly just me being me, but in reality it does save me a lot of time in a commercial cabinet shop situation. Then there is the fact that I am almost exclusively in the shop. I have no need to be mobile, so I don't have to save space or have the need for versatility where one tool may have to do several things to earn it's space.
I can identify with the bold text, but I’m self employed.
It sounds like you are buying tools with your own money to improve your productivity for the benefit of your employer which really does seem excessive, but I don’t know your compensation plan.
I do get the impression that your role is critical in the company’s ability to satisfy it’s clients and that you get a lot of satisfaction from your work, so maybe it works out just fine.
Yes, you are correct. I buy everything that I use on my own, except consumables. They buy the Dominos, Zeta connectors, saw blades, sandpaper, etc. As I said before, part of it is just me being me. Some of that is because I can afford it at this stage of life. The investment has paid off. I have been doing this for quite some time and worked my way into it by upgrading as I went, but only as needed. I have told the story before, but you may not know, that I lost it all to a fire. That was nearly 2 years ago (August). So while replacing everything and moving into a much bigger space, I have gone with the system approach of the Festool gear. That is not all I have, of course, but experience has shaped my choices. I had some Festool stuff before, but not nearly as much as now. A big insurance check allows you to go with different choices, since I didn't have to justify to myself when replacing something that worked just fine. I wouldn't have upgraded a lot of the things I had, if not for the loss. They worked before, so I would have kept them until there was a genuine need. Some of it is just from learning about and experiencing the Festool equipment for myself. As I got into it, the draw to continue is there too and the Systainers do appeal to the OCD.
As far as benefitting the company, sure it does, but that comes back to me too. It's not like they don't know or appreciate the effort. Part of it is also from developing better ways of doing things over a period of time too. The Domino and Zeta were game changers in the way I work.
Some of it is just simplicity. If a particular task is easier, it just works out to be faster as a side benefit. Some of it is just satisfaction of getting the job done without having to go looking for a tool or maybe having to wait while someone else is using it. I know how they are taken care of and adjusted. I can pick up anything I own and expect it to work the same as the last time I used it. And I know where it is, no hunting for anything. Efficient is just faster as a secondary effect too.
Part of it is that I came up in the automotive trade, where you basically had to have everything to do the job at hand. If you didn't have the required tools, the job went to someone who did, so you didn't get the hours. That mentality hasn't gone away. So, when I get a particular project and come across a challenge that I haven't seen before, I work through it. Sometimes I think of a better way as I go, but I am not equipped for it. That becomes the next purchase, so I have it next time, that adds up.
Yes, there is a lot of satisfaction from the job. I have had a few architects come to the shop to see their ideas/designs actually get built. That's always nice.
